you could, but u need to put double the normal voltage thru the circuit (250, 500 and 1000v) for the insulation test and you need to check the earthingRusslk said:Couldn't you use an ohmmeter? What does it test?
TillEulenspiegel said:Nigel is correct , I haven't heard of such a thing ( believe it's a standard in the UK ) . I googled and the impression I got is that the thing measures regular V,A , load characteristics but also leakages by all supply lines to earth ( like a GFI for us Yanks) and supply VS load specs.
badflyer said:Thanks for the info guys ! Ive not come across any circuits on the web for such a appliance.
Do you need to be a qualified electrician to certify your equipment using one of these? how can i find out? i'm a electronic engineer
