Pads printout in ARES
ppppking04
Hello,
I am using the ARES lite v6.3 SP3. Have designed a PCB layout. However when i print the layout (in both printer or in .pdf) the inner drill hole for the pads comes to be very small.
I tried changing the pad style (150-60/120-60/100-50/dil). The max i get is around 30 mil inner hole in the print and this is uniform for all the packages. The display in ARES shows the proper inner bore. I am printing using the artwork option. The drill pattern output does give proper holes. However i need the layout print.
Can anyone please suggest some help!
Thank you!
