GabrielTYM
Hi~ i'm designing an overvoltage protection circuit and an overcurrent protection circuit. Been considering mosfet n bjt for those designs, bt nt sure hw to design it~ Is scr usable?
We need a circuit concept. But no, an SCR is not usable for one simple reason...you can only turn an SCR on, never off. Once it's turned on, it stays on unless something else reduces the current to zero (like a relay, or an AC wave crossing zero). That's the two big reason why SCRs are used for AC and not DC.
SCR in a protection circuit is used to short circuit the supply and blow the fuse, not to switch off the load.
What is the load current/voltage and how is it controlled ?
SCR's are commonly used for over-voltage, it's called a crowbar circuit.
crowbar circuit would need to insert fuse wanx right?
Yes it would, and you really do want to do it that way - over voltage circuits are to protect whatever you're feeding, and crowbar circuits are the best way to do that. You 'could' try and rurn the feed off, but if that circuit doesn't work it will destroy what you're trying to protect.
Crowbars are used because they are simple, cheap, reliable, and provide maximum protection.
Well, if you already use something (usually a MOSFET) to switch your load on/off, you can use that as a protection circuit : sense the current, if it goes above a certain threshold, turn off the MOSFET.
Overvoltage is a bit harder to do. If your power supply becomes crazy and sends high voltage, it could blow your MOSFET driver and the MOSFET could turn on permanently.
An SCR overvoltage protection, on the other hand, is really reliable, because it's really dumb. If you don't like the idea of changing a blown fuse, use a polyswitch.
Ah that's interesting. I would have thought a transistor for that but I guess the circuitry is simpler with an SCR since you don't have to worry about the transistor turning off prematurely.
ya~ that's true. But by using SCR means that i'll be using fuse already, seems to be a bit troublesome when the fuse "burn". ^^
You're rather missing the point - over voltage protection is used when the power supply fails (regulator gone S/C or whatever) - it's to prevent damaging whatever the load is. You WANT it to blow the fuse to keep things safe. Trying to switch off the S/C transistor won't make any difference, your load will continue to receive too much voltage and will be destroyed.
What's "really dumb" is to make comments like that.
An SCR crowbar works very nicely in circuits that have good current limiting, and there'll be no blown fuses.
Erm, apparently i just want to show an open circuit when it reach certain voltages. That's all. As long the circuit can be open circuited by which ever components(MOSFET/BJT) then can already. It's just testing.
Sounds like you have no need for over voltage then?. It's mainly a safety device in case of a failure in the PSU.
