opamp doubt
ccatty
hi friends,
im doin a line follower bot.
i hav 2 doubts.
my comparator output voltage when sensors blocked and unblocked are 3.7v and 2v.
these two are given as inputs to my 89c2051 controller.
the problem here is controller taking both 3.7v and 2v as logic1..
how to reduce the output voltage of comparator from 2v to 0?
or
how to make controller to take 2v as logic 0?
hope u l do clarify my doubt..
thnks
Post a schematic of the comparator circuit and tell us which comparator you are using, etc.
im using LM358 ( 8 pins, 2ports)
1 pin output
2 refernce voltage frm 10kpot
3 input from ldr
4 grnd
8vcc
There are two methods you can try:
1) Replace the LM358 with a LM393 and add a 10K resistor from pin 1 to Vcc (5V).
or
2) Put a 1K resistor between pins 1 and 4 on the LM358.
Method 1 is the best one. Method 2 may or may not work depending on how much current the LM358 is trying to sink.
QUESTION: Is the pin on the 89c2051 controller configured as an input?
WHy not use a microcontroller with a built-in comparator?
