thanks Mikebits, I will have a read of that. I was looking for something with diagrams but failed to find much.
Mikebits showed the circuit types that are used for Class B RF output circuits where the half-wave pulses are used to excite an RF tank circuit tuned to the output frequency.
The type of Class B circuit that MikeMl described are used in op amp output stages or in audio power amp output stages.
Yes most op-amps are class AB but some are A and you can get some which are B.Aren't OpAmps Class B (actually AB1)? They have a totem pole output stage which can actively both source and sink current. The output stage is biased so both transistors are lightly turned on, so if the output is unloaded, the quiescent current is small but finite. They have some crossover distortion.
