No that will short your power supply. The point labeled 14 connects to pin 14 of the IC. And the one labeled 7 connects to pin 7.So, i have to link pin 7 to pin 14.
Thanks 4pyros, You are my savior.
do you mean IC-3 is MOC3041? However, MOC3041 got 6 pin. Howto do the connection in the circuit? In addition, IC3 got an LED reside within as indicated by the author. No found any LED in MOC3041...
Please enlighten me,,,,guys
eric, thanks for yr advice.
Adding transformer and rectified will occupy more space which i not intend to do. Furthermore, if I modify the circuit myself, which involve many calculation, i have not much confidence in myself either.
No thay go to the commen line on the bottom thay just did not draw it all the way down.The grounding point labeled 7 and C1 connected to green grounding wire (from main supply)? Not Chasis grounding or PCB grounding, correct?
