Hi everyone, I hope someone is still reading this thread .. I built the serial servo project Olly's one. The circuit seems to work fine also I checked the MAX232 "+" and "-" 10 voltages and they are correct @ 8.9v. I also checked that the PIC16F84 had +5v from the regulator and everything is fine. I also have made connection with the serial port to Olly's servo software. But when I power on the circuit all the servo does is it just twitch a bit to the left and nothing happens then when I enable the servo and try to move the direction :S I burned the .HEX code from Olly's website the one for the PIC16F84, but although the burning program says PIC programmed successful there is nothing happening :S
I hope that someone here can help me a bit .. or has encountered similar problems. I don't know what I'm doing wrong ..
Thanks in advance matthew
