Really? So they're avalanche rated at breakdown voltage? PIV tests are far different than an avalanche rating.colin55 said:A 1N4148 is simply a 140v zener, so you can test it.
You failed to mention that the current limit resistor is very different in both cases and the wrong one can let the smoke out.colin55 said:I simply said you can test it for zener breakdown at between 90v and 140v.
In this case. No it's not.You failed to mention that the current limit resistor is very different in both cases
