NJM2211 FSK demodulator problem.
s3art
Hi guys,
I tried to build this 1200 baud fsk decoding circuit using this NJM2211 ( the exact circuitary is given in the chip manual -> https://picbasic.com/downloads/NJM2211.pdf) I used the recommand component values fsk decoding too.
I tested the circuit with both a 1.2kHz 1Vpp input and 2.2kHz input, the output at pin 7 was always at 4.x VDC....Shouldn't the output be at "LOW" when my input frequency's at 2.2kHz ?
I wonder why this is happening. Please help =)
* Oh another thing, I set V+ = around +5VDC when i was testing the chip.
Yes, I used the values from table 1 and configured that circuit as given in figure 2. I did use a 5K trim pot as Rx.
Though, I'm not sure if I connected the trim pot correctly.
For the trim pot, there was 3 pins and I only used two of them ( I tested these two pins with a multimeter and the resistance was variable ) and i left the third pin open.
i'm sorry for any misused words ...I'm not really familiar with these stuffs.
and ~ Thanks for the help = )
s3art said:
Anyone ever used this chip before? Please help.
I haven't used it, but I noticed that pin 4, according to the pinout on p.1, should be connected to GND. This isn't shown in Fig. 2.
