Newbie in MPLAP....error while compile
herntan
when i press compile the compiler show
" Access violation at address 00000000. Read of address 00000000. "
i not sure what happend but i just try on the example in the program.
seem it not working and all example show the same error.
may i know is that any setting that i didn't set cause the error to occur?
which pic are u using .wht settings have u made.send the starting config. of the pic code. then only i can help you
are u sure that is a compiler error , it looks like a windows GPF error.
Yes, sounds like a windows error to me too. I'd try it again, and if you get the same, try re-installing MPLab.
Regards,
Robert
Ah, I was just about to ask if you were using CCS C, and saw the subject line of your last post fly by when I hit the reply!
Yes, there has been trouble with licencing on a recent release. If you own this compiler, you should email CCS, as I believe they have a solution.
Regards,
Robert
