New to the Forum and to PIC's
psapg
Hi guys!!!!
Although I have some experience with electronic and it's basic theories, I've never worked with PIC's before...
Now I'm willing to try and chose a "Garage opener" alike project....
My goal is to, by pressing a single press-button, a dc motor(6v or 12V) woul carrya a small load (about 50g) from A to B and Stop, and reverse in the next key press....
Since I do some programing in a Basic alike programing enviroment for the Windows Mobile Platform, I was planig in using PIC-Basic for the code....
What PIC shoul I use? (is 16c54 suited ?)
Any related circuits I should peek?
Should I use a H-Bridge for the motor?
End-of-travel switch: micro-switch or opto-barrier?
Thanks for all your incoming imput...
Paulo Gomes
The PIC16C54 is an OTP device. This means that it can't be re-programmed/updated after its first programming. Choose a flash-based PIC!
Thanks, Eng1
Any suggestions? I believe I only need 5 I/O pins, 1 for the press button, one for each sposition sensor and two for the H-Bridge...
psapg said:
Thanks, Eng1
best is to go for a popularly used device as they wold be cheaper. use as many pins as you need. always go for flash series as suggested ny Eng1. one such is 16F628-4 and try practicing the specifics of this chip as it has adc input pins etc.
we could have suggested 16f84-4 but these might go off the shelves
NO, I wasn't planig on using Leds other that the opto-couplers, if I decide to go with them..
Any caution/example on using these as input to the PIC?
You could try checking my tutorials for some interfacing examples - but opto-couplers are VERY, VERY simpel to connect to a PIC (or any other logic device).
