need to swap a relay w a similar relay where do i look for replacements
jeff jones
the chip is an omron g8p 1ca4p v 18 vdc 250 v
and a g8p 1a4p 30 amp
the cost for shipping from manufacture is 10 times more than the chip itself.
I need a similar US made chip that doesn't cost an arm and a leg.
isn't there a website for comparing and swapping chips w the similar chip just different manufacture
Some of your part number implies one of this family. But from Omron I don't see an 18 volt coil? But your v 18 vdc implies 18 VDC coil? Also these are mechanical relays, why a ref to a chip? The part numbers just don't make sense.
If what you have is what is in the link I provided, you can likely find a similar or like relay from Tyco maybe in their T92 series. If what you have uses a socket rather than just 1/4" spade lugs individual you mat need to change the socket. You don't list a location? Omron is a manufacturer, what you want is an Omron distributor wherever you are.
Ron
