Need the appropriate light sensor
UltimateElectro
I'm trying to design a circuit to detect triboluminescence emitted by crystals. The nature of the light is it lasts only for a fraction of a second and it's very weak in intensity. Assuming that I can make the appropriate environment, like what is described here. I need to make sure that the light sensor can detect the light with such a short duration. Any recommendations for the type of light sensor I need to go by, would be highly appreciated.
do you know more about how long?
What type of light? IR, UV, Red, ?
Very sensitive light sensor are a little slow.
Strong light can be detected in 1/1,000,000 of a second.
Van you put the crystal in a dark box with zero light?
I don't know the exact length, but it's not less than a quarter of a second for sure, if that helps. It emits visible light, usually orange, yellow, or hue. I can put it in a dark box, sure.
The duration of the dim burst of light depends on how you smash the crystal or the duration you pull adhesive tape off.
If you hit the crystal with a hammer then the duration of the light is extremely short. If you pull off a long piece of tape then it might make a few seconds of light.
Have you looked into avalanche photodiodes? I think they'd be handy for what you're trying to do...seem a bit pricey, but I know they're used for detecting even single photons. Might also be overkill :p
I think a low lux video camera will work.
I like the idea of the video camera. It has a million light sensors. Not as sensitive as you want but it will give you more information. Maybe light comes form one end of the crystal and not the other. My camera has red, green, blue and IR sensors. You can replay the video. Many people have a old camera not in use.
