I've got an application where I need a low-cost (reasonably uncomplicated) triggered latch circuit for turning on LED's (each one discrete) and holding them on until I turn them off. In simplest terms: I press a momentary switch and the LED comes on and stays on until I press the switch again, then stays off until I press the switch again...a toggle. Thing is, I need to do a number of these (like 30 or so of them) where a certain LED stays on (or off) until that switch is hit again. I've got a small board all set up, with a clock, so I'm all set for just about any approach. Should I be thinking flip-flops? Latches? Does anyone have a simple circuit that might work for this? If so, maybe something with quad inputs/outputs so I don't end up with a hundred IC's. I'm toying with the idea of a PIC microcontroller, but I've never played with them, and I can't see how it would, for example, hold a particular state for so many LED's independently. If anyone's interested in what the project is, email me direct and I'll be glad to fill in the gaps.
Thanks in advance for any help you folks may come up with.
Garry (garry@jetcoder.com)
