I'm having trouble receiving through the UART on the PIC16F877A. I am able to send from the PIC to the PC but I cannot send data from the PC to the PIC. I am using a MAX232 IC level shifter. And a Linx QS USB module connected to the PC. (**broken link removed**) I am able to receive data from the PIC with and without the MAX232 but the PIC is not able to receive anything.
Also, the MAX232 has 2 TTL-to-RS232 converters and 2 RS232-to-TTL converters. Which ones am i supposed to use from the PIC to PC and PC to PIC?
Here is the code I am using
anyone have any idea what i may be doing wrong?
; Author Claudio RACHIELE IW0DZG
; Working 20000318
list p=16f877,c=140 ; processor type
errorlevel 1, -(305)
#include "p16f877.inc"
__CONFIG _PWRTE_ON&_HS_OSC&_LVP_OFF&_WDT_OFF
temp equ 7Fh ;
; DESCRIPTION
; Baud Rate = 9600, No Parity, 8 bits & 1 Stop Bit
; PROGRAM START
org 0 ; startup = 0000H
clrf STATUS ; bank 0
goto BootStart
org 4
ISR goto 5 ;
org 5
; SET UP THE PORTS TO SUIT YOUR CIRCUIT REQUIREMENTS
BootStart
banksel PORTA ; bank0
movlw b'00000000'
movwf PORTA
movlw b'00000000'
movwf PORTB
movlw b'01000000'
movwf PORTC
movlw b'00000000'
movwf PORTD
movlw b'00000000'
movwf PORTE
banksel TRISA ; bank1
movlw b'00000001'
movwf TRISA
movlw b'00000000'
movwf TRISB
movlw b'11000000' ; set RC6 & RC7 as input
movwf TRISC
movlw b'00000000'
movwf TRISD
movlw b'11101000'
movwf TRISE
movlw b'00000111'
movwf ADCON1 ; porta inputs = digital not analog
; BAUD RATE SETTINGS
; Baud Values with BRGH = 0
; ((20000000/9600)/64)-1 = 32
; movlw d'207' ; 1200 baud @ 16 Mhz Fosc +0.16 err
; movlw d'103' ; 2400 baud @ 16 Mhz Fosc +0.16 err
; movlw d'25' ; 9600 baud @ 16 Mhz Fosc +0.16 err
; movlw d'12' ; 19200 baud @ 16 Mhz Fosc +0.16 err
; movlw d'255' ; 1200 baud @ 20 Mhz Fosc +1.73 err
; movlw d'129' ; 2400 baud @ 20 Mhz Fosc +0.16 err
; movlw d'32' ; 9600 baud @ 20 Mhz Fosc -1.36 err
; movlw d'15' ; 19200 baud @ 20 Mhz Fosc +1.73 err
; Baud Values with BRGH = 1
; ((20000000/9600)/16)-1 = 32
movlw d'129' ; 9600 baud @ 20 Mhz Fosc +0.16 err
movwf SPBRG
movlw b'00100100' ; brgh = 1
movwf TXSTA ; enable Async Transmission, set brgh
banksel RCSTA ; bank0
movlw b'10010000'
movwf RCSTA ; enable Async Reception
movf RCREG,w
movf RCREG,w
movf RCREG,w ; flush receive buffer
; PROVIDE A SETTLING TIME FOR START UP
clrf temp
Settle
decfsz temp
goto Settle
LWaitCom
call RecLoop ; wait and read from RS232
movwf PORTB ; show value for diagnostic purpose
TxLoop
nop
btfss PIR1,TXIF ;xmit buffer empty?
goto TxLoop ;no, wait
movwf TXREG
goto LWaitCom ; no
; RECEIVE CHARACTER FROM RS232
; This routine does not return until a character is received.
RecLoop
nop
btfss PIR1,RCIF ; check for received data
goto RecLoop
movf RCREG,w
return
end
