Need help with infrared distance sensor
momo26
need a filter to an infrared distance sensor
Hello,
i'm trying to make an infrared distance sensor for a project so i find a simple CKT on the attachement but it need some improvment
i want to integrate with it a high pass filter to avoid noise for ex to let only 40khz frequency to pass but i'm not familiar with filter so i need your help
and this ckt detecte only for 1 - 7 cm if you can improve it to get higher distance like 10 or 15 cm it will be better
so if you have any sugestion thank you for replaying back
and sorry for my bad english
Why that 47n cap? It will reduce your output signal if you are using 40kHz modulation of the IR signal. Try removing the cap to get increased range.
hello thnk you for your answer
no in this ckt i didn't use any modulation , i used vcc directly to power the ir led
but i want to implement a simple filter so that i use modulation and cancel the dc ir coming from the sun
thanks
