RayRay1132
I recently got my hands on 60 mini neon indicator lamps and I plan to arrange them into 4 seven segment displays for a clock that I'm building. Any ideas on a good controller for this?
Note: This feature currently requires accessing the site using the built-in Safari browser.
a neon will only light one electrode in the neon if you power with DC. Both will illuminate with AC power. 90v AC at a few milliamperes is typical. Do you know the ratings (or model number) of your bulbs?
I dont know the specifics of the bulbs exactly. However, I had an idea, would it be possible to connect a controller circuit to a whole bunch of relays connected to an ac source, that way instead of powering the bulbs directly from the controller I could power them indirectly from mains voltage with a resistor in between.a neon will only light one electrode in the neon if you power with DC. Both will illuminate with AC power. 90v AC at a few milliamperes is typical. Do you know the ratings (or model number) of your bulbs?
Ik, I was just figuring I could turn each segment on/off individually using a relayA reminder with Neon lamps. if you supply them with some voltage x, they will keep their state. You can change the state by briefly raising the voltage or lowering it.
Yes, that would work. But multiplexing may be difficult with relays because switching speed is slow so you may need 7 Segments x 4 digits = 28 output pins to make this happen. Also, you'll need 28 transistors or 4 ULN2004 transistor arrays to drive the coils on the relays.I dont know the specifics of the bulbs exactly. However, I had an idea, would it be possible to connect a controller circuit to a whole bunch of relays connected to an ac source, that way instead of powering the bulbs directly from the controller I could power them indirectly from mains voltage with a resistor in between.
