need help with coding~~ROBOT
tuan_101
anyway i know there was a topic about this somewhere in the forum but it wasn't what i was looking for, i was given a project at school with programming a line tracking robot, the line is black. we're using a microprocessor the PIC16F628A,
I'm currently using a program call mikroC compiler programming in C code. im planning on using 3 sensors. the middle sensor is always on, and when either one of the sensors on the side goes off it would turn that direction (meaning that the robot has gone slightly off the black duct tape). what how am i going about on doing this? since, I'm very new on C coding and dont really have a clue. can someone show me a code that they've made in the past for this? or an example, or just how am i gonna get started on this. -_______-" i know im asking 2 much but i am hopless at programming.
P.S im running the program at 4.00 MHz in the clocking source for the setting of program.
_MCLRE_OFF - we do not need master reset input
_WDT_OFF - we turn off something called the "watchdog timer"
_LVP_OFF - we are NOT using "Low voltage programming"
_INTRC_OSC_NOCLKOUT - we want to use an internal Oscillator and not have this signal visible at the output pins.
all of that are the setting for my program so far
3v0
Coop Build Coordinator
Forum Supporter
There has got to be code on the internet for a line following robot.
Try David Cook's Robot Room.
If you get started and have trouble with the code or hardware we can help. But you need to be a bit self starting.
3v0
tuan_101
my so caleld codeeeeeeeee~~~
u told me to put schemtic in 3vo, are schemtic = {} <--- those brackets?
#define forward 0b000000101
#define backward 10
#define left 9
#define right 6
#define stop 0
void main()
CMCON = 0x07;
TRISA = 0x00;
PORTA = 0x00;
// setup the PORT that is used by the motors - TRIS, CMCON, etc
while(1) {//ever loop
//forward
if(PORTB && PORTA);
PORTA.F4 = 0 ;
PORTA.F5 = 1 ;
PORTA.F6 = 0 ;
PORTA.F7 = 1 ;
delay_ms(1000)
//backward
if(!PORTB && PORTA);
PORTA.F4 = 0 ;
PORTA.F5 = 1 ;
PORTA.F6 = 0 ;
PORTA.F7 = 1 ;
delay_ms(1000)
//left
if(PORTB && !PORTA);
PORTA.F4 = 1 ;
PORTA.F5 = 0 ;
PORTA.F6 = 0 ;
PORTA.F7 = 1 ;
delay_ms(1000)
//right
if(PORTB && PORTA);
PORTA.F4 = 0 ;
PORTA.F5 = 1 ;
PORTA.F6 = 1 ;
PORTA.F7 = 0 ;
delay_ms(1000)
//stop
if!(PORTB && PORTA);
PORTA.F4 = 0 ;
PORTA.F5 = 0 ;
PORTA.F6 = 0 ;
PORTA.F7 = 0 ;
delay_ms(1000)
EE World Online Articles
Loading
