I am in need of some help in which I think I need some type of latching relays to do what I want.
This is using 12vdc from a regular car type battery.
What I want to do is by supplying a pulse of current turn some regular vehicle headlamps on and off each time the remote button is activated. Then with another button on my remote switch them between high and low beam. The temporary pulse of current needs to hold the function until the button is pressed again. The lights will draw about 25 amps.
I do want to be able to control some snow plow lights with the remote. I have 12 volt power cable from the vehicle to the plow and do not want to use wiring and a switch back to the cab of the truck. ANY help and sources for what I need would be greatly appreciated.
