Need help using LCD.
Im trying to get my LCD display working (first time i've used one) and i can't figureout whats wrong. The code i'm using seems fine, but I'm not 100%. The only other reason i can think it wouldn't work is the contrast voltage Vo is wrong. I've tried altering it and i can change it between dark squares and no squares, but i never get any characters. Please can someone help me?
here is the code i'm using.
; DELAY EQUATES
CNT EQU 0X25 ;ADDRESS FOR COUNTER
CNT2 EQU 0X26 ;ADDRESS FOR COUNTER2
CNT3 EQU 0X27 ;ADDRESS FOR COUNTER3
CNT4 EQU 0X28 ;ADDRESS FOR COUNTER4
; LCD EQUATES AND DEFINES
#DEFINE DDRE TRISB,7 ;DATA DIRECTION
#DEFINE DDRRS TRISB,5 ;DATA DIRECTION
#DEFINE E PORTB,7 ;ENABLE LINE ON LCD
#DEFINE RS PORTB,5 ;INSTRUCTION/DATA SELECT
#DEFINE RW PORTB,6
TEMP_LCD EQU 0X3A ;STORAGE FOR LCD
LCD EQU PORTC ;LCD DATA PORT
CLRSCR EQU B'00000001' ;COMMAND FOR CLRSCR
HOME EQU B'00000010' ;SENDS CURSOR TO HOME
ON EQU B'00001100' ;TURNS ON THE DISPLAY
OFF EQU B'00001000' ;TURNS THE DISPLAY OFF
LEFT EQU B'00011000' ;LEFT SHIFT
RIGHT EQU B'00011100' ;RIGHT SHIFT
LIN2 EQU B'11000000' ;SETS TO LINE 2
; VECTOR FOR NORMAL START UP.
ORG 0
GOTO START
; MAIN PROGRAM STARTS HERE:
START CLRW ; CLEAR W.
MOVWF PORTA ; ENSURE PORTA IS ZERO BEFORE WE ENABLE IT.
MOVWF PORTB ; ENSURE PORTB IS ZERO BEFORE WE ENABLE IT.
movwf PORTC
BSF STATUS,RP0 ; SELECT BANK 1
MOVLW H'00' ; MASK FOR PORTA FOR ALL OUTPUTS.
MOVWF TRISA ; SET TRISA REGISTER.
MOVLW H'00' ; MASK FOR PORTB FOR ALL OUTPUTS.
MOVWF TRISB ; SET TRISB REGISTER.
MOVLW H'00'
MOVwf TRISC
BCF STATUS,RP0 ; RESELECT BANK 0.
CALL INIT_LCD ; Initialse the LCD
bsf PORTA,2
MOVLW CLRSCR ; Clear the screen
CALL COMMAND ; Initiate the command in the W reg
MOVLW .1 ; wait for 1 second
BsF PORTA,2
BcF PORTA,2
MOVLW 'H' ; send h
CALL DISPLAY ; Display the w reg on the LCD
MOVLW 'e' ; send h
MOVLW 'l' ; send h
MOVLW 'l' ; send h
MOVLW 'o' ; send h
MOVLW LIN2 ; Set display to line 2
MOVLW 'W' ; send h
MOVLW 'o' ; send h
MOVLW 'r' ; send h
MOVLW 'l' ; send h
MOVLW 'd' ; send h
MOVLW '!' ; send h
goto $ ; Stop here
;**************************lcdv6******************************
;Porta 1 for the enable and porta 2 for rs/ portb for lcd data
; Initialize the LCD
INIT_LCD:
MOVLW .200 ;DELAY IN MICROSECONDS
CALL MDELAY ; '' ''
MOVLW B'00111100' ;tell display its two lines
CALL COMMAND ;output to the screen
MOVLW ON ;turn on display
MOVLW B'00000110' ;shift along every write
RETURN
; This routine is to set the lcd to the second line
SECOND_LINE:
MOVLW LIN2 ;set to line 2
RETURN
; THis executes a command in the W reg
COMMAND:
BCF RS
BCF RW ;command coming
MOVWF LCD ;PUT OUT ONTO PORT
MOVLW .200 ;delay time in microsecs
CALL MDELAY ;wait a while
MOVLW .250 ;delay time in microsecs
CALL MDELAY ;WAIT
BSF E ;make sure the enable line is up
CALL MDELAY ;WAIT
BCF E ;clock the data in
CALL MDELAY ;WAIT
BSF RS ;return to a data input
RETURN
; This controls the module. When you call this
; routine, the contents of the 'w' register is
; displayed on the LCD screen. It is written in a
; module like this for portability!!
DISPLAY:
BSF RS
BCF RW ;make sure it will accept data
MOVWF LCD ;send data to lcd
CALL MDELAY ;WAIT
CALL MDELAY ;WAIT
CALL MDELAY ;WAIT
CALL MDELAY ;WAIT
RETURN
; 1 MICROSECOND DELAY
MDELAY:
MOVWF CNT ;LOAD DELAY TIME
COUNT:
NOP ;TWO NO OPERATIONS
NOP ;TO OBTAIN THE DELAY
DECFSZ CNT,1 ;DECREMENT THE COUNTER
GOTO COUNT ;GOTO COUNT IF NOT FINISHED
RETURN
; SECOND DELAY, A DELAY FOR 1 SECOND!
SEC_DELAY:
MOVWF CNT ;LOAD DELAY TIME IN APPROX SECONDS
LOOP5:
MOVLW .1 ;LOAD W WITH .42
MOVWF CNT4 ;AND INTO COUNTER
LOOP4:
MOVLW .198 ;LOAD W WITH .198
MOVWF CNT3 ;AND INTO COUNTER
LOOP3:
MOVLW .199 ;LOAD W WITH .199
MOVWF CNT2 ;AND INTO COUNTER
LOOP2:
DECFSZ CNT2,1 ;DECREMENT THE COUNTER
GOTO LOOP2 ;GOTO LOOP AGAIN
DECFSZ CNT3,1 ;DECREMENT THE OTHER COUNTER
B LOOP3 ;IF NOT FINISHED, GOTO LOOP AGAIN
DECFSZ CNT4,1 ;DECREMENT THE OTHER COUNTER
B LOOP4 ;IF NOT FINISHED, GOTO LOOP AGAIN
DECFSZ CNT,1 ;DECREMENT THE OTHER COUNTER
B LOOP5 ;IF NOT FINISHED, GOTO LOOP AGAIN
RETURN
END
hi ED,
Which PIC are you using.?
I have used Pommies codetidy for your code,,, when you post code use the '#' symbol on the menu to keep the formatting...
; DELAY EQUATES
CNT    equ    0X25        ;ADDRESS FOR COUNTER
CNT2    equ    0X26        ;ADDRESS FOR COUNTER2
CNT3    equ    0X27        ;ADDRESS FOR COUNTER3
CNT4    equ    0X28        ;ADDRESS FOR COUNTER4
#DEFINE    RW    PORTB,6
TEMP_LCD equ    0X3A        ;STORAGE FOR LCD
LCD    equ    PORTC        ;LCD DATA PORT
CLRSCR    equ    B'00000001'    ;COMMAND FOR CLRSCR
HOME    equ    B'00000010'    ;SENDS CURSOR TO HOME
ON    equ    B'00001100'    ;TURNS ON THE DISPLAY
OFF    equ    B'00001000'    ;TURNS THE DISPLAY OFF
LEFT    equ    B'00011000'    ;LEFT SHIFT
RIGHT    equ    B'00011100'    ;RIGHT SHIFT
LIN2    equ    B'11000000'    ;SETS TO LINE 2
    org    0
    goto    START
START    clrw            ; CLEAR W.
    movwf    PORTA        ; ENSURE PORTA IS ZERO BEFORE WE ENABLE IT.
    movwf    PORTB        ; ENSURE PORTB IS ZERO BEFORE WE ENABLE IT.
    movwf    PORTC
    bsf    STATUS,RP0    ; SELECT BANK 1
    movlw    H'00'        ; MASK FOR PORTA FOR ALL OUTPUTS.
    movwf    TRISA        ; SET TRISA REGISTER.
    movlw    H'00'        ; MASK FOR PORTB FOR ALL OUTPUTS.
    movwf    TRISB        ; SET TRISB REGISTER.
    movlw    H'00'
    movwf    TRISC
    bcf    STATUS,RP0    ; RESELECT BANK 0.
    call    INIT_LCD    ; Initialse the LCD
    bsf    PORTA,2
    movlw    CLRSCR        ; Clear the screen
    call    COMMAND        ; Initiate the command in the W reg
    movlw    .1        ; wait for 1 second
    bsf    PORTA,2
    bcf    PORTA,2
    movlw    'H'        ; send h
    call    DISPLAY        ; Display the w reg on the LCD
    movlw    'e'        ; send h
    movlw    'l'        ; send h
    movlw    'l'        ; send h
    movlw    'o'        ; send h
    movlw    LIN2        ; Set display to line 2
    movlw    'W'        ; send h
    movlw    'o'        ; send h
    movlw    'r'        ; send h
    movlw    'l'        ; send h
    movlw    'd'        ; send h
    movlw    '!'        ; send h
    goto    $        ; Stop here
;**************************lcdv6****************** ************
INIT_LCD:
    movlw    .200        ;DELAY IN MICROSECONDS
    call    MDELAY        ; '' ''
    movlw    B'00111100'    ;tell display its two lines
    call    COMMAND        ;output to the screen
    movlw    ON        ;turn on display
    movlw    B'00000110'    ;shift along every write
    return
SECOND_LINE:
    movlw    LIN2        ;set to line 2
    return
COMMAND:
    bcf    RS
    bcf    RW        ;command coming
    movwf    LCD        ;PUT OUT ONTO PORT
    movlw    .200        ;delay time in microsecs
    call    MDELAY        ;wait a while
    movlw    .250        ;delay time in microsecs
    call    MDELAY        ;WAIT
    bsf    E        ;make sure the enable line is up
    call    MDELAY        ;WAIT
    bcf    E        ;clock the data in
    call    MDELAY        ;WAIT
    bsf    RS        ;return to a data input
    return
DISPLAY:
    bsf    RS
    bcf    RW        ;make sure it will accept data
    movwf    LCD        ;send data to lcd
    call    MDELAY        ;WAIT
    call    MDELAY        ;WAIT
    call    MDELAY        ;WAIT
    call    MDELAY        ;WAIT
    return
MDELAY:
    movwf    CNT        ;LOAD DELAY TIME
COUNT:
    nop            ;TWO NO OPERATIONS
    nop            ;TO OBTAIN THE DELAY
    decfsz    CNT,1        ;DECREMENT THE COUNTER
    goto    COUNT        ;GOTO COUNT IF NOT FINISHED
    return
SEC_DELAY:
    movwf    CNT        ;LOAD DELAY TIME IN APPROX SECONDS
LOOP5:
    movlw    .1        ;LOAD W WITH .42
    movwf    CNT4        ;AND INTO COUNTER
LOOP4:
    movlw    .198        ;LOAD W WITH .198
    movwf    CNT3        ;AND INTO COUNTER
LOOP3:
    movlw    .199        ;LOAD W WITH .199
    movwf    CNT2        ;AND INTO COUNTER
LOOP2:
    decfsz    CNT2,1        ;DECREMENT THE COUNTER
    goto    LOOP2        ;GOTO LOOP AGAIN
    decfsz    CNT3,1        ;DECREMENT THE OTHER COUNTER
    decfsz    CNT4,1        ;DECREMENT THE OTHER COUNTER
    decfsz    CNT,1        ;DECREMENT THE OTHER COUNTER
    return
    end
i'm using the pic16F690.
 DELAY EQUATES
#DEFINE 	RW	   PORTB,6
        ORG     0
        GOTO    START
		movwf 	PORTC
		MOVLW	H'00'
		MOVwf	TRISC
		bsf 	PORTA,2
		BsF		PORTA,2
		BcF		PORTA,2
        MOVLW   'H'		; send h
        MOVLW   'e'		; send h
        MOVLW   'l'		; send h
        MOVLW   'l'		; send h
        MOVLW   'o'		; send h
        MOVLW   'W'		; send h
        MOVLW   'o'		; send h
        MOVLW   'r'		; send h
        MOVLW   'l'		; send h
        MOVLW   'd'		; send h
        MOVLW   '!'		; send h
	goto		$	; Stop here
INIT_LCD:
CALL MDELAY                        ; '' ''
RETURN
SECOND_LINE:
RETURN
COMMAND:
BCF RS
CALL MDELAY                    ;WAIT
CALL MDELAY                    ;WAIT
CALL MDELAY                    ;WAIT
RETURN
DISPLAY:
BSF RS
CALL MDELAY                    ;WAIT
CALL MDELAY                    ;WAIT
CALL MDELAY                    ;WAIT
CALL MDELAY                    ;WAIT
RETURN
MDELAY:
COUNT:
RETURN
SEC_DELAY:
LOOP5:
LOOP4:
LOOP3:
LOOP2:
RETURN
END
i still can't get it to work. i cleared all then bits in the ansel register but still no joy. let me know if there's anything else you can think of.
thanks again,
ed.
MOVLW .1 ; wait for 1 second <--- It will not be doing any such thing.
BsF PORTA,2
BcF PORTA,2
MOVLW 'H' ; send h     <--- Because you just MOVed 'H' into it.
