My circuit is constructed as below. I'm a new beginner in programming. Desperately need help for the programming of this system. I have modified coding from similar project, but it keep on getting syntax error. Need help in modifying the AVR code for HSM20G into PIC code for HSM20G. Facing syntax error in rx part.
// LCD module connections
#include <p18f4520.h>
#define LCD_RS RB2_bit;
#define LCD_EN RB3_bit;
#define LCD_D4 RB4_bit;
#define LCD_D5 RB5_bit;
#define LCD_D6 RB6_bit;
#define LCD_D7 RB7_bit;
#define LCD_RS_Direction TRISB2_bit;
#define LCD_EN_Direction TRISB3_bit;
#define LCD_D4_Direction TRISB4_bit;
#define LCD_D5_Direction TRISB5_bit;
#define LCD_D6_Direction TRISB6_bit;
#define LCD_D7_Direction TRISB7_bit;
void pic_init(void);
void setup_MCU();
void display_common();
float read_voltage(unsigned short channel);
void convert_for_segments(unsigned long raw_data);
float read_humidity();
float read_temperature();
void display_data(unsigned char x, unsigned char y, float value);
void main()
pic_init();
setup_MCU();
display_common();
while(1)
display_data(1,2,read_temperature());
display_data(1,4,read_humidity());
void pic_init()
TRISA=0b00000011;
TRISB=0b00000000;
TRISC=0b00000000;
TRISD=0b00000000;
TRISE=0b00000000;
PORTA=0b00010000;
PORTB=0b00000000;
PORTC=0b00000000;
PORTD=0b00000000;
PORTE=0b00000000;
void setup_MCU()
LCD_Init();
ADC_Init();
Lcd_Cmd(_LCD_CLEAR);
Lcd_Cmd(_LCD_CURSOR_OFF);
delay_ms(500);
unsigned char disp1[] = "Temperature:";
unsigned char disp2[] = "Relative Humidity:";
unsigned char disp3[] = "C";
unsigned char disp4[] = "%";
Lcd_Out(1,1,disp1);
Lcd_Out(2,7,176);
Lcd_Out(2,7,disp3);
Lcd_Out(3,1,disp2);
Lcd_Out(4,6,disp4);
register unsigned long raw_v = 0;
rx float vin = 0;
unsigned short samples = 0;
for(samples = 0; samples < 64; samples++)
raw_v += adc_read(channel);
raw_v >>= 6;
vin = (raw_v * 0.0048875);
return vin;
register float HSM_20G = 0;
register float v = 0;
v = read_voltage(0);
HSM_20G = ((3.71 * v * v * v) - (20.65 * v * v) + (64.81 * v) - 27.44);
return HSM_20G;
v = read_voltage(1);
HSM_20G = ((5.26 * v * v * v) - (27.34 * v * v) + (68.87 * v) - 17.81);
return HSM_20G;
unsigned char c = 0;
register unsigned long conv = 0;
conv = (value * 100.0);
c = (conv * 0.001);
Lcd_Chr(y, x, 48 + c);
c = ((conv / 100) % 10);
Lcd_Chr_CP(48 + c);
Lcd_Chr_CP('.');
c = ((conv / 10) % 10);
Lcd_Chr_CP(48 + c);
c = (conv % 10);
Lcd_Chr_CP(48 + c);
delay_ms(100);
