As the title says I'm looking for a replacement relay for an auto application....12V system....It is used on a HELLA cruise control PCB
The relay can 5 or 6 pin....there is a place for a 6th pin that terminates at the board, i'll either cut off the extra pin or drill and solder it into place...it is not functional on the board
Form 1 C
SPDT
Here are some pics..
The distance between each of the three pins is approximately 6/32 in....
The distance between the two pins is approximately 4/32 in...
The distance between the the outer most pin in 2 pin group and the upper most pin in three pin group is approximately16/32 in..
Form 1 C
SPDT
