Need help designing a tester for a 25 wire harness
retaftech43
hi
I was wondering if any of you out there have ideas on how to build a 100% correct harness tester. I build wiring harnesses that have 25 same color wires going from one connector to another on different pins. I need to create a tester possibly using LEDs that will light indicating that no wires are crossed. Thanks in advance!
Dennis
You could just multiplex both ends of the wires and then just cycle through each checking if they are connected. And for each wire on one end you could check ever wire on the other so that you could be sure that nothing got accidentally connected. Then you could use leds to display in binary which wires were faulty. Or get a cheap lcd and have it display which wires are crossed with which. A pic with about 18 pins might do it, or I am sure there is another way which might be a lot easier but I prefer to overkill instead with a microcontroller.
