I got this circuit to precharge my LiFEPO4's and well it works but it's a bit dirty in it's cut-off values maybe because the circuit is not ver insulated etc.
http://www.electro-tech-online.com/...ging-circuit-will-this-work.92969/#post740212
The circuit I need to is for a capacitive spotwelder, I need to adjust it so it will charge to various voltage levels (11,11.5,12........15V).
The bank is 2 caps 16V with a total capacitance of 1.22F-1.58F exact data is not availible on that point the value was extracted experimentally, 1RC method gave me the high value discharge over a known resistor gave me the low value. it's somewhere inbetween. Now I have several possiblities when it comes to charging this cap the most likely method in the long run is some sort of battery that will have a voltage of around either 16V nominal or 19.2V nominal the output for most of the discharge curve would be either 18 or 15 respecitively.
So I'd like to have a circuit that does not limit the current but turns the current abruptly off when the cap reaches a pre-selected voltage level (which also determines the availible Ws (joule) for the weld. Hysteresis should be kept to a minimum (0.1V) a relay will disrupt the current flow when a weld is in progress.
I'm asking the following two questions
A. can part of this circuit be reused to cut-off the current flow when the pre-determined voltage has been reached?
B. would using something like a LM 339 be better in this situation?
terramir
terramir
