I am trying to deliver .2A needed to the base of a 2n6059. My frequency generator TTL out only delivers between 66mA and .1A
I have a 680 ohm resistor before the base of the darlington to deliver the frequency.
The TTL impedance is 50 ohms.
How can I get the necessary current to the base of this darlington without changing the frequency. I could work around the frequency change with a counter and just adjust accordingly but id like to do it as cleanly as possible without distorting the waveform.
Here is the datasheet on the transistor: http://www.datasheetcatalog.com/datasheets_pdf/2/N/6/0/2N6059.shtml
Here is a link to my frequency generator: https://www.electro-tech-online.com/custompdfs/2011/09/4017B_manual.pdf
This isnt the exact gen but the specs are the same...mine is older but same model minus the "b"
Thanks for any help.
