need help choosing Dc power supply
mrel
Hello
I am hobby person not a technician person.
Need advice in choosing a variable bench DC power supply that is 0-30 dc voltage and 0-3amp.
I notice there is linear and switching type bench DC power supply.
Since i am hobby person i might use the power supply for all different kind of project,example i might use to test a DC motor or test a LED or what ever need a Dc voltage.
So question is which kind of bench dc power supply would i need Linear or switching power supply.
Thank for the help mrel
Linear is easier. And very reliable. If you go Switched Mode, you are in the realm of complicated design...
You also need reliable SMPS PSU designers on your side to help......Otherwise all blows up....
So for your application @ 0 to 30 VDC can be accomplished with standard off the shelf parts. LM317T comes to mind...
Outboard pass transistors coupled to the regulator will do the job as far as current goes.
Any thoughts Nigel????
Cheers,
TV Tech
Linear every time! :D
A 723 based supply, with perhaps a 2N3773 transistor should do the job.
Hello
Buying or building?
Nigal Goodwin
You mention 723 and 2n3773 transistor what does this mean ,are you saying that I should be looking a power supply that had those 723 and 2n3773 trasistor in there circuit?
mrel
The LM317T is only good for 1.5A, I believe.
A power supply is a good investment. One choice you have is CC or Constant Current and CV for constant voltage and Current Limiting.
Current Limiting is not as precise as a CC/CV supply. Meters for current and voltage simultaneously would be preferred.
If your dealing with Op-Amp, A Dual Supply would also be a good choice.
And Either way, LINEAR with both Voltage and Current Controls.
Hi Mrel,
yes I think Nigel and tvtech both misunderstood your query
you are wanting to buy rather than build in which case switchmode is definately the way to go. Higher efficiency, and much much less weight and usually smaller case size
cheers
Dave
