I want to build a thermostat (proportional i think?) that can maintain a specified temperature within about 1 degree F. It will be set at probably 88F but I will need to be able to adjust between around 70F-100F. I need it to act as a rheostat, not On/Off. I want it to have a display panel that will display the temp that it is set to and also the temp that it is at. I will be using flexwatt heating tape as the heatsource, which is pretty much just like a heating pad with standard wall outlet plugs. I would like it to be able to hold up to around 600 watts and i would also like some type of security so that if it gets too hot it will shut off completely. The temperature probe needs to be able to withstand humid climates and sealed incase of contact with liquids. Can anyone give me some helpful tips on where to start? I'd like to build these relatively cheap. Under $50 bucks if possible..
