Need a way to convert PC fonts into fonts for a micro-controller LED display.
tdg8934
Currently I am using an excel speadsheet to draw out ascii fonts for use in my micro-controller for a LED display. They are given either HEX or BINARY values. I like Binary because I can see them easily and change if needed but HEX values are so much shorter. Is there an easier way or method to auto convert fonts into 1s and 0s or HEX values for let's say a 5x7 or 8x8 font ascii set?
Here is an example:
' ! 21
DATA %11101111
DATA %11000111
DATA %11000111
DATA %11000111
DATA %11101111
DATA %11111111
DATA %11101111
DATA %11111111
it doesn't have to be inverted either.
Nigel Goodwin
Super Moderator
Most Helpful Member
If you're capable you could write yourself a program to do it, but most Windows fonts are Truetype so aren't a simple bitmap.
You could always 'steal' the font from my LED matrix tutorial, I based it on the font in an LCD text module - and did it all by hand.
Mr RB
tdg8934
So it sounds like no one has found a way to create font's for LED signs except by manual entry. I can't believe that all of these LED sign manufacturers created 127+ characters for 'multiple' fonts manually within each micro-controller. Hmm.
ronsimpson
Most Helpful Member
I have stolen the fonts out of LCD displays. Some you can read back the font table. Most have the font information in the data sheet.
tdg8934
Thanks I will take a look. However, this link looks like only 0x00, 0xFF and 0x2F so I don't think thoses are fonts.
EE World Online Articles
Loading
