Need a switching timer circuit
dewslat
Im a noob, so sorry for some wrong terms on this. I can barely solder but I can catch up.
I have this 3 motors with 3 wires out. it has forward and reverse to it. What I want to do is that I want to make each motor run in sequence.
Motor 1 - Reverse .5 Sec.
Moror 1 - Forward 2 Sec.
Motor 2 - Reverse .5 Sec.
Moror 2 - Forward 2 Sec.
Motor 3 - Reverse .5 Sec.
Moror 3 - Forward 2 Sec.
And loops back to Motor 1... and so on
Please please... Just have to do this project. A simple as possible will do.
Start with an astable (555 or something else) that runs at 2Hz (Period=0.5sec).
Now add a four-bit binary CMOS counter(like a MC14161), wired to reset when it reaches the sixteenth state, meaning that it counts 0-14, 0-14,0-14, forever.
Now, add a four line to one-of-sixteen decoder (like a MC14514).
Out0 drives mot1 reverse
A four input OR gate ( like a MC14072) wired to Out1-4 drives mot1 forward.
Out5 drives mot2 reverse
A four input OR gate wired to Out6-9 drives mot2 forward.
Out10 drives mot3 reverse
A four input OR gate wired to Out11-14 drives mot3 forward, at which point the counter resets back to zero, and the cycle begins again. Each motor period is either one clock period or four clock periods.
You will need to add power FETs between the CMOS outputs and the motor windings.
This could also be done with a modest PIC.
Thanks.
wow.. just a diagram would do fine and also the part list.
Thanks.
Sorry, its about half a day's work to detail out the schematic. I gave you enough info so that you can do it yourself.
I Myself would use a 4017
set up the 555 for .5 seconds then feed 2- 4017's
tap off the first output = .5 seconds
# 5 output = 2 seconds then 6 outp[ut = .5 seconds
etc.
lots easier IMHO than reconfiguring the output with gates
do a search of 4017
lots of circuits etc.
How do you get two 4017s to count 0-14 without some gates?
