N-Channel mosfet power question
pigman
Hey, this may sound like a silly question. But can I use a N-Channel FET to switch a positive load?
IE.
Gate - (low trigger) negative
Drain - Load
Source - +12VDC
Just curious if this is an OK thing to do? I'm guessing not. will only work as a P Channel FET?
The FET in question https://www.farnell.com/datasheets/65413.pdf
Cheers
If you connect the source of an N-channel Mosfet to +12V then the load must connect to a higher positive voltage.
The gate will be +12V when the Mosfet is turned off and the gate of this Mosfet will be +17V when the Mosfet is turned on.
If you connect the source of a P-channel Mosfet to +12V then the load must connect to a lesser voltage, usually 0V.
The gate will be +12V when the Mosfet is turned off and the gate of most ordinary P-channel Mosfets will be +2V or 0V when the Mosfet is turned on.
See my post in your other thread. Why scatter this topic into (now) three different forum threads?
