My first code ever, will it work?
Lac
Ok, this is my first pic assembly code i have ever written, so there are surly some errors in there. But what I want to to is this:
I have two buttons, one connected to pin 1 and the other to pin 2. When one of the buttons are pushed, it will drag the pin it is onnected to low, the pic will then detect wich button is pushed (or both at once) and send the correct output to 2 output pins.
I'm not able to test this myself cause I haven't got my pic yet.
Cheers!
Lac.
		LIST	P=16F628, F=INHX8M
		include	"P16F628.inc"
		__CONFIG	0x3DED
		ORG	0x0000
STATUS		equ	03h
TRISA		equ	85h
PORTA		equ	86h
COUNT1		equ	08h
COUNT2		equ	09h
		bsf	STATUS,5
		movlw	00011
		movwf	TRISA
		bcf
check1		BTFSC	PORTA,0
		goto	check4
		goto	check2
check2		call	delay
		BTFSC	PORTA,1
		goto	BANK1
		goto	BANK3
check3		call	delay
		BTFSC	PORTA,0
		goto	BANK2
		goto	BANK3
check4		BTFSC	PORTA,1
		goto	check1
		goto	check3
BANK1
		MOVLW	00000
		MOVWF	PORTA
		call	delay
		call	delay
		call	delay
		end
BANK2		MOVLW	00100
		MOVWF	PORTA
		call	delay
		call	delay
		call	delay
		end
BANK3		MOVLW	01000
		MOVWF	PORTA
		call	delay
		call	delay
		call	delay
		end
Delay
Loop1
		decfsz	COUNT1,1
		goto	Loop1
		decfsz	COUNT2,1
		goto	Loop1
return
end
im not gonna comb through it but your one line is just "bcf" i suppose you mean "bcf STATUS, 5" but i would recommend getting rid of that STATUS bit stuff and just use the standard microchip includes so you can just use RP0...
also "movlw 00011" should be movlw 0x03, or movlw b'00000011'
also you cant use "end" in the code, it will cause the compiler to stop assembling and ignore everything after it, use return to end a call
also you cant do those decfsz's at the end because COUNT1 and COUNT2 are literal values, they are not file registers. You need to use the cblock command to allocate ram for them
see the tutorials posted here they should be a good help...
Good Luck!
Your delay will work fine, but you must remove the end's from bank1.2.3.
loop	goto	loop
or
goto $
make the pic to start endless loop in the same address !
Turn off the comparator otherwise you can't use the porta
movlw	0x07
movwf	CMCOM
USE some kind of simulator/emulator to debug your code !
MPLAB SIM
PROTEL's DEMO
Picsimulator
