Multiple Indirect addressing Code Problem
Suraj143
Active Member
I’m using 10 GP registers in the ISR to show the display. For that I’m using indirect addressing. (Only reads the INDF)
In my main menu also I’m using indirect addressing to update the above 10 GP registers.(Writing to INDF)
I’m using the same 10 GP registers in both cases.
Problem is the display is working nicely. But the update stuff never happens.
Do I have to save something in the ISR? I’m using only bank0 in PIC16F628A.
Pommie
Most Helpful Member
You should save (and restore) FSR in your ISR. If that doesn't work then post your code.
Suraj143
Active Member
Hi mike thanks for the help.
Is this correct way to save FSR?
Save_Context	movwf   WT           	;save W register
		[COLOR="Red"]movf	FSR,W
		movwf	S_FSR		;save FSR	[/COLOR]
		movf	STATUS,W        ;move status register into W register
		movwf	STAT
		movfw	PCLATH
		movwf	p_temp		;Save PCLATH
Rest_Context	movfw	p_temp
		movwf	PCLATH		;Restore PCLATH
		[COLOR="Red"]movf	S_FSR,W
		movwf	FSR		;Restore FSR[/COLOR]
		movf    STAT,W
		movwf	STATUS          ;restore STATUS register
		swapf   WT,F
		swapf   WT,W          	;restore W register
		retfie
Pommie
Most Helpful Member
No, you have to save FSR after you save STATUS,
		[COLOR="Red"]clrf	STATUS[/COLOR]
		movwf	STAT
		movf	FSR,W
		movfw	PCLATH
You should also clear status (as shown) so that variables STAT, S_FSR and p_temp can be in the normal (bank 0) area. WT still has to be in the common area (0x70-0x7f).
Suraj143
Active Member
		movwf	STAT
		movf	FSR,W
		movfw	PCLATH
A very very good comment you did.That will be work for sure.I'll try & tell the latest progress.
Thanks for the excellent correction.
Nigel Goodwin
Super Moderator
Most Helpful Member
I would also suggest you rethink your programming - it's important to keep an ISR as short and fast as possible - you certainly don't normally want to be doing display routines in there (with the exception of multiplexing for them).
Suraj143
Active Member
Hi Mike after saving context correctly it was worked perfectly.That was a really good point.
Thanks Mike.
Nigel I'll think about your idea thanks for that hint. :)
EE World Online Articles
Loading
