Hi All,
My first post here, although I have 'lurked' for a few weeks.
I am building an RF Amplifier and have an 18F4682 for use as a controller and display driver
(see circuit diagram / schematic)
I have eight ADC inputs to monitor varios voltages, all of which are between 0 - 5v (I will use a potential divider to scale higher voltages like that from the 48 volt supply).
To test the unit, I used a 2k2 trimmer across a 5v supply, and a series resistor of 2.7k (I just happen to have loads of these values! - I also used them as 'R' in the DAC).
The inputs do work, but seem to 'sink' the voltage on the input when approaching 5 volts. Also unconnected inputs seem to vary in sympathy with the voltage applied to connected input.
I then decided to use eight 2k2 trimmers and 2k7 series resistor , but still no luck, now the inputs stay stubbornly low - maybe i have damaged the inputs!
I have read that these type of effects can occur, someone mentioned using decoupling capacitors near the inputs, but I am not really sure what was meant (I understand what a decoupling cap is, but not what was meant in this context).
Do I have to use OP-AMP buffers or should I use higher values of pots , series resistors for this test Jig, and what about in the actual amp?
i may have damaged the PIC inputs, but before try (damage!) another new one, I would appreciate your advice!
Andy
I
Andy
I
