2camjohn said:Is it possible to do these DIY.
If so are their any websites with guides on it??
Nigel Goodwin said:2camjohn said:Is it possible to do these DIY.
As far as I know they are just thin boards glued together, so to make a three layer board make one double sided, one single sided, and glue them together. Obviously you have to accurate with the registration between the two boards!.
Also make VERY! sure you wash every trace of etchant off the boards - the very first Pace Digital Satellite receivers (exported to South Africa) had a massive failure rate because of that. The PCB manufacturer hadn't cleaned the boards properly, and after a few months the slight traces of etchant between the layers did it's job, and etched through the tracks :lol:
Noggin said:but I suppose this face is hard to forget
