MPLAB Warnings
AtomSoft
How do i create my own warnings in MPLAB?
Like in VB6 i would...
debug.print "my message"
and it would place that in a window in the bottom. How can i do the same for mplab? i know its possible
You need the error directive,
        if $>1234
        error  "Out of memory"
        endif
Edit, you can also use messsage if you don't want the assembler to stop.
works now the problem is ... is sudden....
I want to debug my code. Like if it runs into a certain area then load the warning/error
#warning works like #error only on compile
You can't do that in your source as the compiler doesn't know where the linker will put the code. You have to change the linker script.
ok ill tell you what i did to get what i want...
I made a array 40 bytes long:
unsigned char debug[40];
Now everytime i use this variable array i clear it using:
memset(debug,0,40);
Now i create break points to determine very easy the status of certain things:
sprintf (debug, "Init OK!");
Now using the watch window i can see if it passed or failed without going through code.
another example:
    res = pf_mount(&fs);
#ifdef DEBUGON
    memset(debug,0,40);
    if(!res)
        sprintf (debug, "Mount FS Passed!");
    else
        sprintf (debug, "Mount FS Failed!");
#endif
Plz i have problem when compile the file and tell me that in the Output:
Debug build of project `D:\TEST\TEST.mcp' started.
Language tool versions: mpasmwin.exe v5.34, mplink.exe v4.34, mcc18.exe v3.34
Preprocessor symbol `__DEBUG' is defined.
Sun Dec 27 19:52:45 2009
Clean: Deleting intermediary and output files.
Clean: Deleted file "D:\TEST\TEST.mcs".
Clean: Done.
Build aborted. The project contains no source files.
Debug build of project `D:\TEST\TEST.mcp' failed.
BUILD FAILED
Clean: Done.
BUILD FAILED
listen you have to add the files to the project panel
thats all
