Really?? Isn't this emitter follower? The voltage to the motor is 5 V - 0.7 V, because the driving transistor is the npn type. Or I'm wrong?toto11 said:yes motor run on 12 V
but wire with connected with parallel port run on 5 V
bananasiong said:Really?? Isn't this emitter follower? The voltage to the motor is 5 V - 0.7 V, because the driving transistor is the npn type. Or I'm wrong?
Ya, right. I forgot that serial port supplies up to 12 V.ericgibbs said:hi,
The drawing isnt very clear, but the collectors of the two motor drive transistors are connected to +/-12Vdc, so the motor should get a voltage -0.7V less than what is coming out of the Serial Port TXD pin.
If the Serial TXD swings +/-12V then the motor should get +/-11.3V approx.
