Motocycle Horn
Rumieus
Does motocycle horn function like a speaker?
Whats are the different?
Motocycle horn are water proof right? How about speaker?
Thank ÝòóÙ
Um...Ok, so what's your point? BTW, From the dictionary; a circuit is a circular journey or one beginning and ending at the same place; a round.
Well there sort of the same I guess, in the sense that both take electricty and make sound, but as Blueroom says, I horn is more of a buzzer with a single tone. I horn will make noise by simply connecting a direct current to it, a speaker needs a circuit to generate a tone in order for it to make a sound.
I don't know that a motorcycle horn is waterproof...... Weather resistant maybe, but certinly not made to be used under water.....
The original post was edited thus making my last post seem like nonsense.
It's an electromechanical buzzer.
. . .working at a freq. designed to cut through traffic noise.
Cars have dual horns with a high and low tone, the high to cut through noise and the low to carry distances.
I didn't know that, some bikes have dual horns too.
I make a siren circuit and connect the output to motocycle horn, the sound was very low..
but when i connect the output to speaker, the sound is loud.
So what's the problem?
Thank You
It takes much more current to drive the horn, which is likely to be rated for 12V and quite a few A, than the small amount required to drive the speaker.
inspirational message for the day
A guy gets into a motorcycle accident. He can't find one of his arms. It's on a nearby rooftop.
The horn is not a speaker.
If you try to drive it with enough power to be loud then it will just go beep.
Stick with the speaker - it's designed for the job.
If you want to use a horn then use two different frequency horns and switch them alternately.
