Motherboard problem pls help
Ezugudor
Hi Pls help me my laptop motherboard is coming up but cant display on the screen.If i remove the processor,it will be blinking yellow light showing absence of processor,and if i put the processor back,it will blink green light showing presence of processor.I have tested the processor,RAM,and the screen with another system of exact type and they are working perfect.Pls is there any thing that i can do to make the motherboard to be coming up.
Thanks 4 reading
When you tested the screen on the other system, did you test the inverter with it or did you use the inveter from the other machine? I had a laptop once that looked like the screen had died but it was really just the inverter that powers the backlights. I couldn't see that the screen was working unless I looked at it under bright lights and at an off angle.
