I'm trying to protect my h-bridge mosfets from short circuits while testing. I am using SFP30N06 mosfets which are rated to 30amps continuous drain and 120amps pulsed. I am using 2 12V lead acid batteries (ie. 24V), so to limit the current to 120amps I would just need to add in a 0.2ohm resistor (make it a bit more for safety). For my application this resistor would not have a significant effect on performance, but my question is this: would the mosfets tolerate a 120amp pulse for long enough in order for the fuse (a standard 15amp fuse) to blow so that the mosfets are not damaged?
