mobile phone battery question
ulot
Hi i want to ask
I was told by a gsm engineer that if your battery is not working properly, you can 'boast charge' the battery or reconditioning it.
Please can you explain further before i say what he told me cos' someone else gave me a contradicting view
Lithiums degrade severly every reconditioning period.
About 20% of the capacity is lost after a Lithium is reconditioned the first time, and the equipment needed to do this professionally cost some cash.
Hello
someone actually told me that before
but i want to ask how do you go about reconditioning and 'engineers' here usually use a simple voltage regulator to (as they call it) 'boost' the battery using a much higher voltage than it usually allows but someone else says that you should actually use a very low voltage and a high current to do that. that's where my question is.
From what I have seen so far, "re-conditioning", as it applies
to Li-Ion, is pulse-charging, and for NiCads, discharging to a
safe level and recharging at a controlled rate. Pulse charging
allows a much higher charging current (and rate) than the
allowable (usually C/10) "standard" charging rates. The
charge profiles are unique to the battery chemistry and
construction, and the it is usually wise to follow the
manufacturer's recommendations. Some consider pulse-
charging to be "re-conditioning" on any battery type.
I have done considerable testing on lead-acid batteries
with pulse spikes (as opposed to pulse charging) with
some success in desulfation; I intend to see if similar
results are obtained in other chemistries.
see the battery recovery section on:
www.txucom.net/~andysm
<als>
Hello
thanks for the extra knowledge
but tell me what you think of this atempt to 're-condition' a Li-ion battery:
the battery is not working and not charging, so the engineer (so to speak) takes the two wires of a voltage regulator, sets it to about 12 voltes, ties the each wire to a probe of a multimeter so he can tell which is +ve and which -ve while 'boost charging' as he calls it.
so the readings on the voltmeter keeps rising until it gets to the desired value after just a few seconds.
he puts the battery back into the phone then charge normally.
is this process ideal for 're-conditioning' a Li-ion battery?
I think the "so-to-speak" engineer is in for a big problem:
1) He connects the Li-Ion battery to the 12V regulator.
2) The phone rings, someone's at the door or he takes a pee.
3) He gets back to the battery to find his house on fire!
Lithium burns something like magnesium! Hot stuff.
A Li-Ion battery that is over-discharged is supposed to be charged at a very low current.
Read the warnings on the web from any battery manufacturer.
