Mitsubishi WS-65611 Projection TV, Green Blinking Light......
datheriault
Please help, I have a Mitsubishi WS-65611 Projection TV and moved it out then back in house, powered it up and now only get a green blinking light. I have searched web to find this seems common and the DM power capaciters were under rated at factory, and fail prematurely. I have looked things over and see no reason why not to try replacing the 7 capacitors with a better suited one. But, has anyone ran accros this exactly? Any tips? Thanks a ton. I will not give up to this TV.
Have you checked the bulb? Take it apart clean the airways check the bulb, if it still doesn't work then go for the caps.
