missing TRIS register
eng1
I am using the PIC12F508.. I want to define I/O pins, but I can't find the TRISIO register. Any suggestion?
It's an older PIC, you need to use the TRIS instruction to set the TRIS register, unlike the newer PICs which give direct access to the TRIS register the same as other SFRs.
Read the data sheet for the 12F508, it clearly states how to set it under the I/O Port section.
Pete
Actually it's a relatively recent PIC but uses the old 12-bit instruction core.
Pete is correct in that you must use the TRIS instruction.
Mike
William.. i think it should be
MOVF PIN_DIRS,0
TRIS GPIO
OPTION is another one...
MOVLW b'10101010'
OPTION
10Fs serie work the same way
Thanks for all replies. The program is ok now:
MOVLW 0 ;0 is loaded into the W register
TRIS GPIO ;all outputs
To make all pins outputs, the two instructions should be:
movlw 0h ; 0 is loaded into W
movwf trisio ; W is loaded into tris
You may need to use capital letters for some assemblers:
MOVLW 0h
MOVWF TRISIO
Colin Mitchell
<mod edit: self promotion deleted>
