Hi All
Apart from doing some basic electrical work back in high school (13 years ago) it would be safe to say that I have lost some skills and require some assistance.
I purchased a clock radio from the US (I live in Australia).
I then purchased a step down converter so it would work and it does just fine however the time is out by 10 seconds. Every “real world” 60 seconds the clock radio thinks it’s 70 seconds.
The manual of the radio states that it should be running at 120 V 60Hz. When I tested the Hz going through the clock radio with a multimeter is only comes up with 50Hz (Point C on the below image).
On the back of the clock radio there is a place where it looks like a switch should be to allow me to change between 50 and 60 Hz. It’s a big leap of faith although I’m guessing by making it run at 60Hz will fix my issue.
Upon opening the baby up and taking a quick look around it would appear that there is something missing on the PCB board that should link point A and Point B to convert the 50Hz to 60Hz. Point B registers at 50Hz although the other two points go nowhere (It’s not a double sided PCB).
The switch on the side adjusts the clock radios brightness and also set the time.
Would anyone have any idea what is missing?
Or tell me what I need to buy to make it run at 60Hz?
Any help would be appreciated, this clock radio is 25 years old and it’s a rare find as it was still new in the box. It would be great if I could put it to some use.
Cheers!
Cheers!
