I'm looking at using this relay for an automotive circuit. I want to make sure I understand the minimum power in the coil that will still activate the relay.
The datasheet specifies a pick-up voltage of 5.5V and a coil resistance of 225Ohm. Is it correct to assume, then, that the minimum power required to activate the relay is:
P = I^2*R = (5.5V/225Ohm)^2 * 225Ohm = 134mW
Or are there other factors I need to consider? I ask because I will be using an N-channel MOSFET to activate the coil and the FETs I'm looking at have fairly high Rdson. During an ignition start, a bad battery might dip pretty low, so I want to calculate how low it can go before the circuit won't work anymore.
Thanks!
Thanks!
