Minimum load for 3V voltage reference?
Flyback
Hello,
I wish to use the MCP1703 voltage regulator to produce a 3V reference voltage from a 3.3V rail.
(it will provide the reference voltage for a microcontrollers ADC reference input)
What is the minimum load current that i need to load the output with in order to get the output voltage accurate at 3V?
The datasheet graphs seem to show a minimum current of 1mA flowing.
What will the accuracy be like if only 100uA flows?
MCP1703 datasheet
https://www.electro-tech-online.com/custompdfs/2013/06/22049f.pdf
I don't see anything that says it won't work, but I think I would use a shunt reference like the LM4041. Better initial accuracy and much better specs at your load. Probably cheaper?;)
that 525mV is for 250mA supply current, this will be supplying one mA or less....hopefully less.......but thats what i dont know from looking at the datasheet.
Thanks, i read that, but with MCP1703, on page 7 of the datasheet they have graph 2-13 which shows dropou voltage less than 0.1V for less than 10mA output current.
Then I guess you have to try it, but keep in mind that it is just a regulator, not a precision reference.
I think what bothers every one is why you would want to use a poorly spec'd part for your application when there are available parts with worst case specs for about the same size and cost? :confused:
There's that.
Many modern MCUs designed to work with analog stuff have built in precision voltage references for just this reason.
PS why not use a precision shunt regulator like the popular TL431?
PPS Flyback, who is specking the parts for your design? They all seem like really odd choices for an emergency lighting system.
the ADVREF pin of SAM3N takes 250uA so with TL431 we get loss in the resistor that it needs.....MCP1703 needs no resistors, just the regulator itself, so it will be less lossy and easier on the battery in long mains outages.
Ths software guy chose the sam3n
Yea, But it only takes 65 ua. instead of his 250 - so almost 4X better. Sorry, just being a ---;)
