Hi all.
please excuse me, im not the best at all this electronics stuff, but i consider my self fairly knowledgeable at it.
i am looking to create a circut for charging car batteries, but basically i need/want to use the same type of circuitry and charging systems, and stages as found in a cTek battery charger. i am looking to incorporate it into something that i have invented. but after looking through the forum for hours, and having square eyes, i am lost.
i am also looking for a circuit (for the same invention) where it is basically a voltage sensitive relay, where when the voltage of A is at X volts, then the relay auto engages, and parallels both batteries; the voltages will also need to be set to a predetermind limit for cut-in, and cut-out. but i am lost as to how to make that as well. i have gotten a circuit sorted for charge time switching between the batteries, but i am looking to make an all in 1 box, that does it all. and i am happy for it to be on a PCB, as long as i can get it made and the components easily and cheaply, im after something reliable, and can be made watertight (by the use of seals or silicon) heat generation shouldn't be a problem, as i can use exterior heat sinks and stuff.
so, if that makes any sense to you, can you help?
for those that dont know what a ctek charger is, **broken link removed**
i currently own a powertech plus charger, its basicly the same as the ctek, but cheaper. here is a link to it:**broken link removed**
and i also currently use thease vsr's in my car: BLA: Boating's Leading Accessories
Cheers
Jbates58
Cheers
Jbates58
