When measuring votage with a volt meter does the reading equal the total voltage present or does it equal the difference in voltage between the two points?
I havent found a clear answer to this question and im not sure my measurment is correct. if the later of the above two lines is the truth, how can i test the supposed GROUND point im using to see if its a true GROUND or if there is some voltage present?
