making -9V supply
Electricman2K5
Hi I need to create power supply from batteries only with +9v, and -9v for input into an opamp and LM565 PLL
How can I do this?? Please help
chemelec
Easiest and Cheapest way is to use Two Batteries in series. Zero Volts is the junction between the two batteries.
evandude
that won't be very reliable though, because unequal loads on the + and - supplies will cause the batteries to discharge at different rates.
you could use a MAX660 and provide it with +9v, and it outputs -9v. from what i've heard though it doesnt' provide a very clean output so if you need a precision -9v, you should output something like -12v and then use a 79L09 regulator to regulate it down to a clean -9v.
Teletech
Chemelec's way would be much simplier unless, of course, you are powering a pace maker.
Juglenaut
so like I need 2-12 volt batteries to run a dual rail op amp in a car. Hmmm seems easy?? I rather find a IC that can switch polarity wouldn't you.
EE World Online Articles
Loading
