Thirty years ago, I designed and built this door (50'X 18'):
using only equations in Mechanics Handbook and a calculator (i.e. pre-PC days). It has withstood many Minnesota Winters and thunderstorms without a problem. Generally, I use L.A.R. when designing something. But now, I want some other opinions.
I am faced with converting a Lesco compact sprayer:
to a 3-point hitch. The hitch will be on the long side of the tank. The sprayer tank is 200 gal (1600#) max. Assume the motor + pump are about 100# and the reel is also 100#.
Given this hypothetical structure:
for one side of the 3-pt hitch, what size tubing/channel should be used? I prefer tubing for looks and ability to weld both sides; although, a mixture of tubing and channel is no problem. My gut tells me that 2X3X1/8 or heavier will be fine. The 3-pt attachments will be 3/8 hot-roll plate.
Is there a good online calculator for cantilever beams?
John
PS: I've gotten older, dummer, and lazier in 30 years. L.A.R. = looks about right.
John
