Hello everyone,
I have posted on here recently about making an accurate low ohm meter. I have still not achieved this and would appreciate some help.
Previously I came to the conclusion that the panel meter display itself was inaccurate. I have recently purchased a good quality one from Farnell (order number: 9932801). However I am still getting the same problems as before, the display does not show the readings I would expect.
Attached is a simple layout of the circuit, below are my experimental findings:
LOW OHM METER EXPERIMENT:
Parts:
Regulator = LM317
Ra = Adjustment resistor
Rload = Resistor to be measured
Vs = 6V
When:
Ra = 120Ohm
Rload = 2.2Ohm
Vload = 0.024
Panel meter reads 1.87
When:
Ra = 120Ohm
Rload = 4.4Ohm
Vload = 0.047
Panel meter reads 4.10
Also I tried a variable resistor for Ra, so that I could adjust the the panel meter display to read the correct resistance:
When:
Ra = Variable resistor
Rload = 2.2Ohm
Vload = 0.028V
Panel meter reads 2.20
When:
Rload = 4.4Ohm
Vload = 0.054V
Panel meter reads 4.80
When:
Rload = 6.8Ohm
Vload = 0.082V
Panel meter reads 7.53
As you can see from my findings, the panel meter display can be way out. I also experimented with a different type of regulator the LM234, I tried using both a 120ohm resistor and a 1KOhm resistor for Ra. I still got inaccurate results. I really would be thankful for some help on this one, I have no idea why these displays should not read an accurate reading.
Parts:
Regulator = LM317
Vs = 6V
When:
Ra = 120Ohm
Rload = 2.2Ohm
Vload = 0.024
When:
Ra = 120Ohm
Rload = 4.4Ohm
Vload = 0.047
When:
Rload = 2.2Ohm
Vload = 0.028V
When:
Rload = 4.4Ohm
Vload = 0.054V
When:
Rload = 6.8Ohm
Vload = 0.082V
